BlackBerry Thread
Relax, sit back and crack open that beer. Talk about anything.
Stranjo Grumps.....ami aindo no problems cu mi Bold 2
This hopefully is my next phone
Motorola Droid 2
Specs
http://www.motorola.com/Consumers/US-EN ... -US-EN.alt
PietjeZz
Post by PietjeZz »
kidsensation wrote: HSDPA is ultra-fast....phone is scary fast....i got flash support in my browser.....a freakin AMOLED screen.......mi notifications ta super cool......mi tones ta sve.....Apps, apps, apps FREEEEE!!!!!!!!!!!
Anto si bo ta un GEEK, Android ta pabo.......imma GEEK.........so?
Time for an ANDROID thread? :idea: :biggrin:
My tshirt on order:
shameless propaganda! anto live riba forum asina? tur hende mester sa bo ta un geek? :laffin:
Just joking! ami mi storm tey keto bai! 2 anja plus y ta traha perrrfect! y awo better yet!
Thanx for the update kid! :idea:
OS6 for Blackberry Bold 9700
version: 6.0.0.344
http://rapidshare.com/#!download|31|428 ... exe|162385
Install Tips:
1) There have been many issues created by restoring 3rd party apps and backup files when moving from an older OS to OS 6. You should avoid this. Either do a full wipe or tell apploader NOT to restore your 3rd party apps and backup data.
Do a backup manually beforehand, then either wipe or run apploader. Don't use DM - I don't think you can tell it not to.
Once you have OS 6 up and running, manually download your apps and use your backup file to selectively restore ONLY data like contacts/calendar/memos/tasks/messages etc.
See the bottom of this post for full instructions if you aren't familiar with them.
Uninstall any OLD BlackBerry OS versions from your computer if you have them. You can find your installed programs in Windows by going to control panel/programs and features. You're looking for "BlackBerry Device Software".
Install 6.0.0.344 to your computer. This means you double click on the OS.exe file that you downloaded and let Windows install it.
Plug in your phone and use Desktop Manager 6.0 (DM) to make a backup of your device.
Close DM and go to:
C:\program files(86)\common files\research in motion\apploader\
From there delete vendor.xml, if it's there, then run loader.exe
Follow the instructions - make sure you look closely at the list of items that have or do not have check marks next to them so you install what you want and don't install what you don't want.
When the popup asks if it should make a backup of your device and restore your 3rd party apps, it should be selected to do it. Change it to NO, do not restore.
Wait about 20-30 minutes for the process to complete and your phone to reboot completely before disconnecting.
Wait a few minutes and do a battery pull. Try to do another battery pull in the next hour as well, just for good measure.
You can then open DM and choose to restore from a backup file. Choose the latest file and click the box that lets you select items to restore. Only choose items like contacts/calendar/tasks/memos/messages etc. Nothing else should be restored unless you know it's just user data and not settings.
Manually install the latest version of your apps and make sure they work correctly. Go through OS6 and redo all the settings the way you like them - this will help you learn the new menu layout.
Pa e OS 5. Esaki te ultimo update .979. Startup ta mas lihe, overall e ta traha un tiki mas lihe.
https://www.blackberry.com/Downloads/br ... 2871.node2
Grumpy wrote:OS6 for Blackberry Bold 9700
version: 6.0.0.344
Grumps ami ta running e OS6, must say I am impressed.
Tin algun bugs ainda si... E tin un memory leak na ordo...
Waiting pa e next release...
Mi ta bezig ta hang riba e OS 5 ainda ki. Porta e next release mi lo instale. E 5.0 ta super stabiel.
g4LLiT0
Post by g4LLiT0 »
Blackberry o.s OS 6.0.0.358 hopi miho cu e previous release cu mi twt tin riba mi bold, e no ta memory leak mane un loco ora bo wak e profile pics riba bbm etc.
http://hotfile.com/dl/83862261/0459ca5/ ... 8.exe.html
[url=Image]Image[/url]
