grumps ki boso ta pensa di e mod aki pa boso aristo? eta traha riba supra pero minsa si elo traha riba e aristo tambe..
http://www.speedforsale.com/supraparts//product_info.php?cPath=33_60&products_id=90
Our Electronic True Twin Conversion ON/OFF Kit ('E-TTC Kit' for short) was developed/produced by Jeremy Blackwell and allows you to change your Supra's stock twin turbo operation between normal 'sequential' mode and 'parallel/true twin' mode by simply flipping an ON/OFF switch! This modification is great for road racing, racing from a roll, and at the strip (with drag radials) for the following reasons:
-Reduces the chance of bearing/shaft failure in the #2 turbocharger since it's always working instead of going from a near stop to full boost within a few hundred RPM's (which eventually warps the shaft.)
-Provides more power between 3300 and 4300 RPM's, and allows the car to hit peak boost a couple hundred RPM sooner.
-Power delivery is much more smooth, and causes less wheel spin in comparison to standard sequential operation delivering power all at once. It makes your car feel like it has a tiny single turbo on it.
-Gives your exhaust that DEEP throaty sound at idle and at lower RPM's!!
-Looks nice and tasteful mounted on your Supra's dash!
