New power plant for my ranger
Ranger4oH
Post by Ranger4oH »
Hey guy's ktk mi ta bezig cu un new power plant pa mi ford ranger,sigur ta bai tin algun ford lovers cu lo no ta di akwerdo pero ja :biggrin: .Mi tin un 2jzgte twin turbo cu auto trans ecu, harnas + tur otro accessories pa un complete swap na caminda.Pa awor aki e lo keda den su stock form i automatic, den futuro mi lo kier hacie manual i bai over pa single turbo etc etc.... boso mes sa e storia.Wel e motor aki ta algo nobo pami i sigur sigur lo mi ta bai tin mester di pointers tocante electronics i performance mod's.So 2jz guru's sigur lo mi ta bai tin pregunta pa boso.Danki di antemano.
Omar.
wel saki ta sigur un projecto unico cu ami lo sigui di serka :D :aruba2:
keep us updated
Ranger4oH
Post by Ranger4oH »
Sigur sigur,mi mes tawata busca tur caminda riba web i google search pa wak si mi por topa cu un swap asina pero nada.Algun dia pasa mi a bin logra topa cu un guy riba TheRangerStation.com cu tambe tin mesun planes.Pero e tambe ta curu curu ainda.
Omar.
Boy...esey lo hasi dushi...pickup ta lightweight mes. Bo no kier a bay e v8 route mes anto mane tur otro.Different,bon ohm....bms,pics.
Speedyrolla
Post by Speedyrolla »
Owh,more plp going over to JZ power,succes cu e project :thumbsup:
2JZ power, trust me once you go to that engine no tin miho!
haha(nissan traitor)
pero ku e 4.0 liter v6 ey bo twt ta korre den 12 abou toch? well 2jz ta un bon motor ..well good luck !
Ranger4oH
Post by Ranger4oH »
12.73 tawata su mihor tempo cu stock internals,cu mod's e lo por miho pero con reliable e ta bai ta ariba higher power levels mi no sa.Niung hende jega di pusha e motor aki na su limit pa sa cuanto e lo por wanta,i mi no tin gana di hanja sa door di trials and errors.So best bai pa algo cu mi sa tin e capacidad i ta reliable.Bms power i speed ta addictive i semper bo kier mas.
Omar.
Zero
Post by Zero »
Nice...good luck dude...pics are always welcome.....
Patience is a motherfucking virtue, let me tell ya!!
I have pissed off everyone I know at least once...the ones closer to me....at least twice....
Conventional wisdom says to know your limits. To know your limits you need to find them first. Finding your limits generally involves getting in over your head and hoping you live long enough to benefit from the experience. That's the fun part!
Good luck Omar. Mi ta sigur bo lo make it.
Tremendo project...
Keep nos up to date...
Post pics!
nice project.... pics pics pics :D
Ranger4oH
Post by Ranger4oH »
Thanks pa e support guy's hopefully e lo jaga fin di luna aki of un siman despues.Pura pa e jaga pa caba pa cuminsa traha ariba dje.E ranger su engine bay ta sunu sunu caba wardando riba e motor.Mi tin un pregunta caba,USDM i JDM spec's 2jzgte segun mi tin compronde cu e usdm tin mas HP door cu e tin differente turbo's,cam's,injectors correcto.Awo segun mi a lesa ta cu usdm ta bin cu MAF i jdm ta bin cu MAP sensor,esey ta correcto of ma compronde robes.
Omar.
bakaracing
Post by bakaracing »
nice project korda pone pic's pa nos wak.any question juist ask kada ken lo por sa un tiki
