FUEL INJECTION
Fuel Injection is a method or system for metering fuel into an internal combustion engine. The fuel is then burned in air to produce heat, which in turn is converted to mechanical work by the engine. In modern automotive applications, fuel injection is typically only one of several important tasks performed by an engine management system.
For gasoline engines, carburetors were the predominant method to meter fuel prior to the widespread use of fuel injection, however various fuel injection schemes have existed since the earliest usage of the internal combustion engine.
Prior to 1980, nearly all gasoline engines used carburetors. Since 1990, almost all gasoline passenger cars sold in the United States use electronic fuel injection (EFI).
The functional objectives for fuel injection systems can vary. All share the central task of supplying fuel to the combustion process in the engine, but it is a design decision whether a particular system will be optimized for power, fuel economy, low emissions, special fuels, durability, smooth behavior ("driveability"), or other objectives. Because some of these goals are conflicting, it is impossible to optimize a single system for every goal simultaneously. For example, maximizing fuel economy or power comes at the price of somewhat higher exhaust emissions. In practice, automotive engineers strive to provide an all-round blend of competing goals to best satisfy customers, all while complying with emission regulations.
An EFI system costs more than a carburetor system, but a greater number of the competing objectives can be better optimized with EFI than a carburetor.
Contents
1 Benefits
2 Regulatory Motivation
3 Basic Function
4 Type of Fuel
5 Detailed Function
5.1 Typical EFI Components
5.2 Functional Description
5.3 Sample Pulsewidth Calculations
5.3.1 Calculate Injector Pulsewidth From Airflow
5.3.2 Calculate Fuel-Flow Rate From Pulsewidth
6 Various Injection Schemes
6.1 Throttle Body Injection (TBI or CFI)
6.2 Continuous Injection
6.3 Central Port Injection (CPI)
6.4 Sequential Central Point Injection (SCPI)
6.5 Multi-Port Fuel Injection (PFI or EFI or SEFI)
6.6 Direct Injection
7 Evolution
7.1 Pre-Emission Era
7.2 Post Emission Era
8 External links
Benefits
An engine’s air/fuel ratio must be accurately controlled under all operating conditions to achieve the desired engine performance, emissions, driveability and fuel economy. Modern EFI systems meter fuel with great precision, and when used in conjunction with an Exhaust Gas Oxygen Sensor (EGO sensor), they are also very accurate. The advent of digital closed loop fuel control, based on feedback from an EGO sensor, permit EFI to significantly out perform a carburetor. The two fundamental improvements are:
1.Reduced response time to rapidly changing inputs, e.g., rapid throttle movements.
2.Deliver an accurate and equal mass of fuel to each cylinder of the engine, dramatically improving the cylinder-to-cylinder distribution of the engine.
These two features result in the following performance benefits:
•Exhaust Emissions
- Significantly reduced "engine out" or "feedgas" emissions (the chemical products of engine combustion).
- A reduction in the final tailpipe emissions (≈ 0.99%) resulting from the ability to accurately condition the "feedgas" in a manner that maximizes the effectiveness of the catalytic converter.
•General Engine Operation
- Smoother function during quick throttle transitions.
- Engine starting.
- Extreme weather operation.
- Reduced maintenance interval.
- A slight increase in fuel economy.
•Power Output
- Fuel injection often produces more power than an equivalent carbureted engine. However, fuel injection alone does not increase maximum engine output. Increased airflow is necessary to permit oxidizing more fuel, which generates more heat, which in turn generates more output. The combustion process converts the fuel's chemical energy into heat energy, whether the fuel arrived via EFI or a carburetor is not significant. Airflow is often improved with fuel injectors, which are much smaller than a carburetor. Their smaller size permits more design freedom to improve the air's path into the engine. In contrast, a carburetor's mounting options are limited because it is larger, it must be carefully oriented with respect to gravity, and it must be approximately equal distance from each of the engine's cylinders. These design constraints generally compromise airflow into the engine.
- A carburetor relies on a drag inducing venturi in order to create a local air pressure difference, which forces the fuel into the air stream. The flow loss caused by the venturi is small in comparison to other flow losses in the induction system. In a well-designed carbureted induction system, the venturi in and of itself is not a significant airflow restriction.
- Fuel injection is more likely to increase efficiency than power. When cylinder-to-cylinder fuel distribution is improved (common with EFI), less fuel is required to generate the same power output. Engine efficiency is known as the BSFC, or brake specific fuel consumption. When cylinder-to-cylinder distribution is less than ideal (and it always is under one condition or another, and worse on carburetor systems), more fuel than necessary is metered to the rich cylinders in order to provide sufficient fuel to the lean cylinders. Power output is asymmetrical with respect to air/fuel ratio. In other words, burning extra fuel in the rich cylinders does not reduce power nearly as quickly as burning too little fuel in the lean cylinders. The standard fuel metering compromise is to run the rich cylinders "even richer" of the optimal air/fuel ratio, in order to provide enough fuel to the leaner cylinders. The net power output improves with all the cylinders making maximum power. An analogy is that of painting a wall. One coat of paint may not cover very well. The second coat dramatically improves the appearance of the poorly covered areas, but some extra paint is consumed on areas that were already well covered.
- Deviations from perfect air/fuel distribution, however subtle, significantly impact emissions, by forfeiting combustion events at the chemically ideal, stoichiometric air/fuel ratio. Grosser distribution problems eventually begin to negatively impact efficiency, and the grossest distribution issues finally affect power. The hierarchy of negative functional impact with regard to increasingly poorer air/fuel distribution is: emissions, efficiency, and power.
Injection systems have evolved significantly since the mid 1980s. Current EFI systems provide an accurate and cost effective method of metering fuel. The emission and subjective performance characteristics have steadily improved with the advent of modern digital controls, which is why EFI systems have replaced carburetors in the marketplace.
EFI is becoming more reliable and less expensive through widespread usage. At the same time, carburetors are becoming less available, and more expensive. Even marine applications are adopting EFI as reliability improves. If this trend continues, it is conceivable that virtually all internal combustion engines, including garden equipment and snow throwers, will eventually use EFI.
It should be noted that a carburetor's fuel metering system is a less expensive alternative when strict emission regulations are not a requirement, as is the case in developing countries. EFI will undoubtedly replace carburetors in these nations too as they adopt emission regulations similar to Europe, Japan and North America.
Throughout the 1950's and 1960's, various branches of United States federal, state and local governments conducted studies into the numerous sources of air pollution. These studies ultimately attributed a significant portion of existing air pollution to the automobile, and concluded air pollution is not bounded by local geographical or political boundaries. The limited scope local pollution regulations were gradually superseded with more strategically comprehensive, and therefore more effective, state and federal regulations. By 1967 the state of California (Governor Reagan), created the Air Resources Board (
http://www.arb.ca.gov), and in 1970 the U.S. Environmental Protection Agency was formed. Both agencies now create and enforce emission regulations from automobiles, as well as most other man-made sources.
Additionally, similar studies and regulations were simultaneously being developed in Europe and Japan.
The primary source of internal combustion engine emissions is the incomplete combustion of a minute fraction of the total fuel consumed. The unburned portion of fuel is so small, the lost energy is trivial to fuel efficiency, and therefore commercially insignificant to the final customer. Auto manufacturers were finally motivated by various regulations worldwide to address the emission issue.
The modern EFI system evolved to achieve deliberate control of the small fraction of unburned fuel. The ideal combustion goal is to match each molecule of fuel with a corresponding molecule of oxygen so that neither has any molecules remaining after combustion, (see stoichiometry). This is a gross oversimplification of complex combustion chemistry, that occurs in a complex environment. However, it accurately describes the magnitude of the control task, and therefore the desired precision of a modern EFI system.
