Oil filter re-visited
Let's help each other. Cars stuff, computers,girls, etc.
Siguiendo e thread aki http://www.racejunkies.com/forums/showthread.php?t=4388, mi tbt pensa riba e tipo di filter cu mi ta usa den e Camry. Mi ta usando oil filter largo. E tin e mesun base chikito manera kalke oil filter cu e 2E, 4A, 3S/5S ta usa numa cu e ta mas largo.
Ja cu mi no a haja un contesta drechi (of satisfactorio, con cu bo kier) di otro forumnan, mi tin di check akiriba. Mi pensamento ta cu ademas di e extra filtration area ta bon toch pa bo tin extra capacidad pa situashonan di "just in case". Ki boso ta pensa??
Te unda mi sa, tin 2 preferencia cu oil filter.
1. Oil capacity. Den mi caso, tin hende ta usa V8 filters riba nan 6 cylinder paso e filter ta tene mas zeta.
2. Oil flow capacity door di e filter. Tin filter ta hasi miho trabow den filtra sushi den zeta. E malo ta cu e lo no flow bon door di bira mas restrictive.
Kada donjo di auto, dependiendo di kiko e kier hasi cu su motor lo skohe segun su preferencia. Ami ta Toyota original mi ta usa, cambiando pa TRD pronto pa hanja mas flow.
Personalmente, mi ta kere cu e bottleneck lo keda e filter mes. Ki bal bo tin capacidad grandi, y un restrictive filter. E oilflow lo keda malo, ni masque den e filter bo tin 1000 galon di zeta warda.
well ami mes ta usa un oil filter un tiki mas grandi cu e stock,but it worked pretty well till now.
i mane Grumps a bisa ta berdad cu bo tin un oil filter grandi di mas anto e ta restrict flow.
but in my case it's working
Bo sa, ja cu nos TABATA riba e topico aki lo mi trese back from the buried cu e link aki:
http://minimopar.knizefamily.net/oilfilters/opinions.html#recommended
Mi a check rond (e banda aki di Aruba at least) anto hopi ta bisa cu esun oil filternan cu bo no por confia ta esnan fei China. Awo, si bo no sa miho.... ta con lo bo por distingi nan fei esunan original mes mes?
Ongeacht, claro, si e ta capacidad regular of mas.
Boso sa, hasta entre e 4AGE nan tin distinshon den uso. Ata un voorbeeld y check bon e part number-s-nan.
