Greddy Turbo timer plug and play harness pa EP91 Starlet Glanza V
pic coming up
Fls. 45
Nissan SR20DE pistons & Piston Rings Kit
Prijs: fls. 200.00
Full gasket set pa Toyota Camry 1988-1991 V6
Fls. 50.00
Mickey Thompson tubes
16x11.5
Brand new, never used.
Fls. 260.00
ACT sprung 6 pad race clutch disc
E ta pa clutch pa e 6-speed Getrag pa Supra twin turbo. Part number 6250623. Specification:
Disc diameter: 250mm
Input Spline: 14
Spline Diameter: 1.250 inch
Disc material: Ceramic
Prijs: Fls. 250
Vortech Fuel management Unit
Rising fuel pressure rate ta 8:1.
Prijs: Fls. 100
Shift Knob
pa shifter M10. Nobo nobo, nunca usa. Mi a paga fls. 67.50 pe. Mi kier Fls. 25
2JZGE Head. Comes with cams, and head bolts
Completely reconditioned by GJ Performance.
Fls. 500.00
2JZGE valve covers
Fls. 100.00
Lower 2JZGE intake manifold
Fls. 150.00
2JZ Fuel rail
Fls. 75.00
Stock 2JZGE pistons/rods combo
Fls. 200.00
5" diameter aluminum pipe
Bon pa intake pa turbo
On hold, sale pending.
Oil Return section di 2JZGTE. Por wordo usa pa un 2JZGE adapta pa turbo.
Fls. 35.00
[b]Almost new OEM Toyota 2JZ Thermostat
Fls. 35.00
Toyota Thermostat Housing
Snout ta mas cortico pa asi tin mas espacio pa intercooler pipe pa turbo. No a use nunca.
Fls. 40.00
2JZ brand new exhaust manifold studs
Fls. 50.00
Stainless steel 50mm wastegate flange
Fls. 10.00
2JZGTE injector plugs. Pa usa 550cc injector di Supra TT bo mester cambia pa e plugsnan aki
Fls. 30.00
MKIV Supra brake duct mouldings, side mouldings and rear mouldings
Complete Supra set for fls. 150.00
Toyota Pressure Sensor
fls. 25.00
Toyota Pressure sensor
fls. 25.00
MKIV Supra right door handle
fls. 50.00
2" Couplers
Tawata di un upper radiator hose di aluminium
Fls. 15.00 each
2JZGTE Timing gear + trigger wheel
Fls. 45.00
Toyota Alternator regulator
Fls. 100.00
Mi tin algun JDM parts for sale:
Electronic Controlled Ground Kit
Fls. 75.00
Jama 737-0379 of email/msn messenger:
BB Pin:280796b7
Semper por negocia e prijs.
Por hasi package deals tambe, tuma contact pa negosha. Prijsnan ta necogiabel
