Mitsubishi f5m42 gearbox issue help needed
Let's help each other. Cars stuff, computers,girls, etc.
galant4u
Post by galant4u »
ktk friends despues di twt riba un lay low siman pasa mi a bay kuminsa ku e swap di e EVO porfin FINALLY den e auto despues di a drey rond di dje pa 2 anja caba
pero mi a hit un brick wall no algo out of this world pero mi mester di advice seeing ku na Aruba nos tin hende ku hopi conocemento di swapping i costum fitting
di dia mi a cuminsa ku cumpra motor etc mi a hanja sa ku na merca na ta couple e gearbox mitsubishi f5m42 riba e evo motor nan 4-8 anto ku djies un costum headers pa clear e starter tur ko ta traha perfect
ora mi a bay wak mi auto su tranny ki e ta a resulta ku e ta e f5m42 mi di den mi mes "NET" wel awo mi a bin hanja sa ora ma bay pege riba e evo ku e tranny dimi e f5m42 aki ta e model pa mirage dus e bellhousing ta otro
awo ami mester un f5m42 5speed manual saka di un eclipse 2000-2003
un hende por sa unda mi por bay pa wak si tin ? asina ki e mester ta
http://rover.ebay.com/rover/0/e11051.m4 ... ORS%3A1123
anto on a more technical advice mi a bin ripara ku lesando ku supuestamente e gearbox di lancer 2002-2007 tambe ta f5m42 esaki tambe lo traha e ora ???? paso riba ebay tin e poni ku e ta fit evo engine ??
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
any input suggestions welcome
galant4u
Post by galant4u »
mi mester usa e f5m42 pa mi por keda fwd
Te unda mi sa e gearbox e 3rd gen Eclipse 2000-2003 ta fit riba e evo 4-8 engine block. $975 pa un brand new gearbox ta ganga. Ami a paga $2300 pa esun di mi auto
galant4u
Post by galant4u »
Chai wrote:Te unda mi sa e gearbox e 3rd gen Eclipse 2000-2003 ta fit riba e evo 4-8 engine block. $975 pa un brand new gearbox ta ganga. Ami a paga $2300 pa esun di mi auto
anto bo no por sasi e gearbox nan di e lancernan 2005-2007 tambe ta fit paso nan a traha lancer manual anto 4g64 den nan
galant4u wrote:anto bo no por sasi e gearbox nan di e lancernan 2005-2007 tambe ta fit paso nan a traha lancer manual anto 4g64 den nan
Segun mi nan mester por fit. Paso tur e gearbox bon di e 4G series ta fit e 4G series engine. Depende ki banda e gearbox ta situa. Eclipse 1990-1999 y e EVO 1-3 e gearbox ta na left side. EVO 4-9/Eclipse 2000-2003 e gearbox ta na right side .
galant4u
Post by galant4u »
ok man hopi thnx pe info mi tey wak si mi por hanja un somewhere of mester bestel un e ora mi kier a hanja un pa test fit prome pa mi no bestel ko robez pero mane mi ta wak ta djies bestel fingers crossed .....
galant4u
Post by galant4u »
Chai wrote: Paso tur e gearbox bon di e 4G series ta fit e 4G series engine .
e uniko problema ku a mi a hanja mi mes aden awoki t ku mi a pensa mescos paso mi motor twt 4G93 pero e no a fit
dUDE, mi ta papiando di punto di bista di toyota awo. Si e input shaft ta fit, e uniko hurdle lo ta e actual fitmento di e bellhousing na e motor. M'a wieta cu un dude di edad a fit un gearbox di Toyota na e motor di su Mazda cu un mod chikito na un di e horeanan di e bellhousing mes. Kemen (ami ta djies asumi) si bo tin e suerte cu e bellhousing por kita di e gearbox, bo por mix and match un ke otro housing n'e gearbox anto jega bolt up sin niun otro mods na bo motor.
Sino bo mester check of traha un tipo adapter pa casanan cu otro.
Mi ta wak na bo pregunta cu bo sa cu awo cu bo a ripara kaba e verschil den bellhousing. Um brotherdi Korsow ta contami cu ela jeg'i traha fin di anja pasa riba un Dodge Stratus anto guess what? Yup, these use this same gearbox too.
galant4u
Post by galant4u »
seps ginox stratus coupe anto sebring coupe tambe ta fit parse both powered by mitsubishi 4g64 engine
E $975 nobo porta un Chinese clone.
Mi por trese Aruba un used 00-03 Eclipse 5-speed den bon condishon pa Fls 2000 den bo man.
galant4u
Post by galant4u »
Grumpy wrote:E $975 nobo porta un Chinese clone.
se ma desifre caba hahaha
tin un naaruba mi tin ku papia ku e guy ainda e ta papia di 2000 tambe i ma kabi hanja un n florida
galant4u wrote:se ma desifre caba hahaha
Ba hanja un pa test fit? Prome bo cumpra un anto e no ta fit tampoco...
galant4u
Post by galant4u »
RaceJunkie wrote:Ba hanja un pa test fit? Prome bo cumpra un anto e no ta fit tampoco...
mane e ta mustra ku na aruba e no a existi of nan no kier fia pa test fit dus ta djies bay tray instinct anto ku e part number di mitsubishi mes ku e mericano a usa MD978020
e ta zona ODD pero ta e harsh truth tur caminda mi a bay "no esey si no tin ,di baina a bin aruba,etc etc" i na ultimo nan a bin ku" no e guy kier 3000 pe" awo minsa si ta kune inclui dus sera wowo check mi mester corre
Cheetos
Post by Cheetos »
Supose e Gearbox di e otro 4G nan lo pas e.
Dus eingelijk un gearbox di un ralliart ku ta 4g64 of ta 4g69 lo mester por pas na bo motor.
E manera di mas fasil pa sa ta.
Los e Plate di heru ku ta tussen di Gearbox ku motor anto pas e ku un Gearbox.
Pero korda paga tinu si ku lo bo tin di FAB e support nan.
Minsa si e ta bai bolt on riba existing holes nan.
Otro kos tambe korda riba e drive shaft nan.
galant4u
Post by galant4u »
cheetos mi bro abo ta un dokter den swap swa wak ki mati e burako nan mas ariba riba e gearbox tur dos ta tight anto un di e bandi starter ey manjan mi ta hanja e bolts nan di flywheel un tiki mas largo pa mi por pone e assembly (flywheel/clutch/pressure plate) paso ma hanja un set ey pa fit wel e la mane mustra ku e ta center pero e shroefnan di e fly tawata cortico manjan ney mi ta load e pics kue pega pa tur ku kier wak , wak i duna opinion . e ta mustra ku ta djies dos orea mester abow.
anto e cv joint ku bo kier emmm e gearbox ki twt den mi auto kaba dus ta djies e powerplant ta cambia mesun support stock and alles
Cheetos wrote:Supose e Gearbox di e otro 4G nan lo pas e.
