No videos yet
Motor:
VQ35HR Stroked to 4.2L
Greddy Twin Turbos (Two 20G Turbos with larger compressor wheels) Ported & Polished
CP Pistons
Brian Crower Rods
Brian Crower Billet Crank
Ferrea 2mm over sized competition valves, springs and titanium retainers
Ported, Polished and Reflowed Heads (Flowed 37% more than stock)
Engine completely balanced and blueprinted
Tomei Pro Cams
Block sleeved by Darton
Custom Designed 6061 T6 Aluminum Twin Throttlebody Plenum
All components have been Cryogenically treated in an SubZero Cryo unit
1600cc Injectors
Exhaust:
Ported and Polished Headers
Ceramic Coated Headers and Exhaust System
Greddy Ti-C Exhaust
Suspension:
Tein SRC Dual Dampening Coilovers with External Reservoirs
2 Tein Electronic Dampening Force Controller (EDFC) Units cockpit mounted
Tein 16kg Springs Front and Rear
Tein Tie Rods
GTSpec 2 Point Rear Lower Brace
GTSpec Front 4 Point Ladder Brace
GTSpec Front Lower Tie Brace
GTSpec Rear Lower Tie Brace
GTSpec Rear Lateral Arm Brace
GTSpec Fender Braces
Hotchkis Adjustable Sway Bars
PowerGrid Swaybar Endlinks
SPL Adjustable A-Arms
SPL Adjustable Rear Toe Arm
SPL Adjustable Rear Trailing Arm
Stillen Core Support Bar
Whiteline Front and Rear Urethane Bushings
Whiteline Rear Traction Bushings
Whiteline Sub-Frame Bushings
Custom Roll Cage by SnR Performance
Brakes:
Greddy 8POT Front Calipers
Greddy 4POT Rear Calipers
Greddy 385MM Slotted Front Rotors
Greddy 335MM Slotted Rear Rotors
Greddy Stainless Steel Brake Lines
Stillen Master Cylinder Support Bar
Cooling and Fuel:
Greddy Performance Radiator
Greddy Oil Cooler
Greddy Air Diversion Plate
NISMO Thermostat
AEM Stage 1 & 2 Fuel Return System with 3 pumps
Custom Brake Cooling Duct System
ARC Belly Pan
Rear diff cooler
Transmission Cooler
Transmission:
OS Giken Triple Plate Racing Clutch
OS Giken Racing LSD
Rear Axle Brace
Electronics:
Haltech Platinum Pro
Greddy Infometer Touch Complete System with all sensors
Greddy Profec B-Spec II Boost Controller
Greddy Profec Remote Switch
DashDaq Datalogging System with Accelerometers
Video Datalogging system is still to be determined.
Stillen Grounding Kit
