Review.
Spec.
The HPF Feramic Full Face clutches are the highest HP holding clutches available for the MK3 Supra. These single disk clutches will both hold up to 700rwhp with ease. The HPF Feramic Full Face is the ultimate for streetability and longevity.
The material used to make this clutch is very expensive. It is also very hard to get. It has the highest heat resistance of any other clutch material made today with a coefficient of 0.7. This coefficient also doesn't change with temperature as many clutches do until after 900 degrees. It has a melting point of 1600 degrees.
This clutch is for Supra's that drag race and have between 500 and 700rwhp
1jz stock flywheel for 150 awg
1jz stock drive shaft for 150
