It has recently been repainted, so there are no scratches, dings, and no oil leaks anywhere.
It has put down 540 hp to the wheels at 25 psi. Street trim is around 400hp to the wheels.
It has a well built engine mechanically capable to 800hp to the wheels.
The following are modifications done to the car:
- ENGINE -
* JE pistons Titan Motorsports Street specifications
* Eagle H-Beam rods with thicker ARP 2000 rod bolts
* New Toyota Main bearings
* ACL race rod bearings
* ARP main studs
* ARP head studs
* 2JZGTE head gasket
* 2JZGTE oil pump
* New valve seals
* New front and rear main seals
* New timing belt
* New accessory belt
- TURBO KIT -
* Stainless steel exhaust manifold
* Master Power T70. Turbine housing A/R 0.68
* 50mm HKS Wastegate
* 4' thick intercooler and aluminum hard pipes
* Turbonetics Godzilla Blow Off Valve
* Turbonetics Manual Boost COntroller
-EXHAUST-
* 3 inch stainless steel downpipe
* 3 inch stainless steel midpipe
* 3.5 inch Tanabe exhaust
-FUEL-
* -8AN fuel feed line
* 2x walbro fuel pumps
* 6x 850cc fuel injectors
* Aeromotive fuel pressure regulator
- DRIVETRAIN-
* ARP flywheel bolts
* Horsepowerfreaks 6 puck Ferramic Clutch kit
-ELECTRONICS-
* HKS turbo timer
* Defi link with white BF series Boost, Exhaust temperature, Oil pressure gauges
-ECU-
* Greddy e-manage Ultimate ( fuel and ignition)
-SOUND-
* Pioneer headunit, ipod and USB memory enabled
* upgraded pioneer speakers
-EXTERIOR-
* Toyota Aero package
* New quicksilver paint
* 18 inch wheels and tires
A lot has been invested in this car. Serious buyers only.
Please no tire kickers, no joyrides, no deals.
Cash only.
Price: AWG. 30.000
Call: +297-737-0379.
Shipping to other islands is possible, and are to be carried by the buyer.
