Wirering diagram EP71 starlet
Let's help each other. Cars stuff, computers,girls, etc.
Rav's Toy
Post by Rav's Toy »
jave nan ktin tur kos ta ok
mi ta den un kos aki....auto ta kla but tin 2 3 kos di electro ta kansa mi nami splika den fast
un kos ku mi a faya ku ne dia mi a kumpra e starlet ta ku mi no a tira un bon bista riba su waya nan esta su harnass
dikon paso mi no ta keda kla ku e waya ku ta connect riba e plug di reverse esei ta 1
2 eigenlijk ora mi pone switch on 1 - lus di bateria mester sali ( no ta saliendo awoki) 2- lus di e handrem mester sali ( tmpko no ta saliendo)
ma buska online prome ku mi jega aki nan but mi no ta kedando satisfecho ku e resultado nan
si un di boso nan por sa di un site pa mi por hanja mira kua ta e waya nan of plug whatever di toyota starlet ep70 ( starlet kuadra manera bosnan ta jame)
laga mi sa as soon as
paso mi tin ku bai keur kos gani sali buta poko hende drumi malo pa kaba hahaha joke ohm ( pami no kansa ) :thumbsdn:
thnx amigos !
regards :cmplimnt:
Raveena's Toy Starlet EP 71 4AGTE Power[color="#FF0000"][/color]
Esaki mi primo ta usa pa tur EP7 Strarlets cu e a jegi traha ribanan cual tin e motor 1E den nan
http://pdfcast.org/pdf/ep70-electrical-diagram
Un paar di part numbazz pa e motornan Nissan NEO
coolant temp sensor 22630-44B20
crankshaft seal (front) 13510-53J10
crankshaft seal (rear) 12279-AD205
fuel filter 16400-0M200
gasket cylinder head 11400-1N500
gasket plug 13271-2j201
gasket valve cover 13270-2j201
hose (water pump) 14055-2J200 ( at rear of engine just above oil filter)
oil filter - engine (purolator) L14610
oil filter - (pitwork) AY100-NS006 or AY100-NS004
oil pan - lower 1110-1N510
oil pressure switch 25240-8996E
piston (sr16ve) A2010-1N560
piston (sr16ve n1) A2010-1N521
piston ring 120331N510 [same as sr20de roller rocker]
pump water - sr16ve n1 21010 - 1N526
timing chain guide (slack side) 13091-2J202
timing chain guide (tension side) 13085-1N500
tps 22620-31I0A
water pump (sr20ve) 21010-53J05
13020 1N503 SR16VE intake cam
13020 1N509 SR16VE exhaust cam
11044 1N500 SR20VE head gasket
12200 2J200 SR20VE crankshaft
13500 1N501 SR20VE front cover and oil pump
14036 1N500 SR20VE exhaust manifold gasket
16600 1N500 SR20VE fuel injectors
22100 1N510 SR20VE distributor
22157 1N510 SR20VE distributor rotor
22162 1N511 SR20VE distributor cap
22401 1N516 SR20VE NGK BKR6E-N spark plugs
22680 5J000 SR20VE MAF (mass air flow sensor)
13020 8H600 SR20VET intake cam yes the turbo cams!
13020 8H610 SR20VET exhaust cam
11110-2J210 SR20VE oil pan. This is the same as the 2000-2001 SR20DE
